StarTech.com 1m 3.3ft 10G SFP+ DAC Cable
Quicklinx: D9T7WS00 Mfr#: J9281BST
Select:
£32.89 ex VAT
£39.46 inc VAT
Connect your HP 10GbE SFP+ network devices with this cost-effective, passive Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
  • Reliable performance
    Designed for high-speed networking, this cable supports 10GBase technology, providing effective data transfer rates and reduced signal loss, essential for demanding applications.
  • Secure connectivity
    Both ends of the cable feature latched SFP+ connectors that ensure a firm connection, preventing any unintended disconnections during operation.
  • Durable construction
    The cable's PVC jacket contributes to its durability, making it suitable for various environments while protecting the internal wiring from wear and damage.
  • Temperature resilience
    With an operational temperature range from 0°C to 70°C, this cable is capable of functioning in diverse settings, ensuring consistent performance under varying conditions.
  • Wide compatibility
    Compliant with standards such as SFF-8431, SFF-8432, FCC, RoHS, and MSA, this cable is compatible with a wide variety of devices and networking equipment.
StarTech.com HPE J9281B Compatible 1m 10G SFP+ to SFP+ DAC Twinax, 10 GbE SFP+ Copper DAC 10 Gbps Low Power Passive Mini GBIC/Transceiver Module DAC Firepower 1040, 10 Gbps SFP+ Cable - Lifetime Warranty (J9281BST) - 10GBase direct attach cable - 1 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Passive cable
Length
1 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
HP J9281B
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
30
Impedance
100 Ohm
Passive cable
Length
1 m
72 g
Connector
SFP+ - latched
SFP+ - latched
HP J9281B
FCC, RoHS, MSA
70 °C
