StarTech.com 1m (3ft) Black Apple 8-pin Slim Lightning Connector to USB Cable for iPhone  iPod iPad
Quicklinx: 9M73WS00 Mfr#: USBLT1MBS
Colours:
Charge and sync your Apple Lightning-equipped devices, even when inside a protective case. The USBLT1MBS 1m Slim Lightning to USB Cable is colored to suit black iPhone, iPod, and iPad mobile devices and provides a reliable solution for charging and syncing your Apple devices with your PC or Mac computer, through an available USB port.
The cable offers a slim Lightning connector housing which plugs into your device even while it is inside a protective case, so you won't have the hassle of constantly removing the cover each time you charge or sync. Plus, the reversible 8-pin connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This lightweight cable also provides a portable solution that makes it perfect for carrying as a laptop or iPad accessory.
The USBLT1MBS is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 3 ' / 1m USB Lightning Cable for iPhone iPod iPad - Black - Discontinued, Limited Stock, Replaced by RUSBLTMM1MB (USBLT1MBS) - Lightning cable - Lightning / USB - 1 m
Cable
Shielded
American Wire Gauge (AWG)
24/32
Length
1 m
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
P/N: ST1030USBM
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Shielded
24/32
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
Sync and charge
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
P/N: ST1030USBM
