This Mini DVI to HDMI Adapter cable features one 32 pin mini-DVI Male and one HDMI Female connector, allowing the video signal from a mini DVI equipped device to be output to an HDMI equipped TV set or A/V Receiver.
This is the perfect solution for using your HDTV instead of a computer monitor, or watch movies directly on your TV from your Apple MacBook or iMac Computer.
MDVIHDMIMF will not work with the current MacBooks, it is made for MacBooks that use mini DVI connectors
- StarTech.com Mini DVI to HDMI Video Adapter for Macbooks and iMacs- M/F - MacBook Mini DVI Adapter - Mini DVI to HDMI Cable (MDVIHDMIMF) - video adapter - 20 cm
- Cable
- Video adapter - HDMI / DVI
- Length
- 20 cm
- White
- Connector
- Mini-DVI - male
- Connector (Second End)
- HDMI - female
- Limited lifetime warranty
- Designed For
- P/N: HDMIROTMM6
- Cable Type
- Video adapter
- Interface Supported
- HDMI / DVI
- Length
- 20 cm
- White
- Connector
- Apple mini-DVI - male
- 19 pin HDMI Type A - female
- Limited warranty - lifetime
- Designed For
- P/N: HDMIROTMM6
