Charge or sync your Apple devices, even when inside a protective case. The USB2ADC1M Apple (30-pin) Dock Connector to USB cable for iPhone, iPod and iPad (1m) offers a simple and reliable solution for connecting iOS-enabled mobile digital devices to your computer, for syncing or charging.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- StarTech.com Apple 30-pin Dock Connector to USB Cable iPhone iPod iPad - charging / data adapter - 1 m
- Cable
- Charging / data adapter
- American Wire Gauge (AWG)
- 28
- Length
- 1 m
- White
- Connector
- Apple Dock - male
- Connector (Second End)
- USB - male
- Limited lifetime warranty
- Designed For
- P/N: ST73007UA
- Cable Type
- 28
- Jacket Material
- PVC
- Length
- 1 m
- Recommended Use
- Portable player
- White
- Connector
- Apple Dock connector - male
- 4 pin USB Type A - male
- RoHS, MFI
- Limited warranty - lifetime
- Designed For
- P/N: ST73007UA
