StarTech.com 1m (3 ft) Apple 30-pin Dock Connector to USB Cable with Stepped Connector
Quicklinx: 84PBWS00 Mfr#: USB2ADC1M
Length: 1m
11 In Stock
£8.21 ex VAT
£9.85 inc VAT
Charge or sync your Apple devices, even when inside a protective case. The USB2ADC1M Apple (30-pin) Dock Connector to USB cable for iPhone, iPod and iPad (1m) offers a simple and reliable solution for connecting iOS-enabled mobile digital devices to your computer, for syncing or charging.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com Apple 30-pin Dock Connector to USB Cable iPhone iPod iPad - charging / data adapter - 1 m
Cable
Charging / data adapter
American Wire Gauge (AWG)
28
Length
1 m
White
Connector
Apple Dock - male
Connector (Second End)
USB - male
P/N: ST73007UA
Cable Type
28
Jacket Material
PVC
Length
1 m
Recommended Use
Portable player
White
Connector
Apple Dock connector - male
4 pin USB Type A - male
RoHS, MFI
Limited warranty - lifetime
P/N: ST73007UA
84PB StarTech.com 1m (3 ft) Apple 30-pin Dock Connector to USB Cable with Stepped Connector In Stock £8.21
Length: 1m
