StarTech.com 1ft Coiled Lightning/USB Cable
Quicklinx: BBD4WS00 Mfr#: USBCLT30CMW
Colours:
Charge your iPad or iPhone inside its car mount. This coiled Lightning cable delivers the compact convenience you need to keep your mobile devices charged while you're driving, without cluttering up your car.
Simply plug the cable into your USB car charger and stretch it out to connect your mobile device when you need to charge it. You can extend the cable up to 1 ft (0.3m), to comfortably reach your car-mounted tablet or phone.
When you're not charging your mobile device, you can neatly store this compact cable in your car's storage console or glove box. Plus, it's portable enough to keep it in your laptop bag or carrying case, so you can have it handy when you arrive at your destination and use it as a conventional charge-and-sync cable.
The USBCLT30CMW coiled Lightning cable is Apple MFi certified.
StarTech.com Lightning to USB Cable - Coiled Lightning Cable - 0.3m (1ft) - White - Apple MFi Certified (USBCLT30CMW) - Lightning cable - Lightning / USB - 30 cm
Cable
Double shielded
American Wire Gauge (AWG)
28/30
Length
30 cm
White
Connector
USB - male
Connector (Second End)
Lightning - male
Coiled
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
28/30
Jacket Material
PVC
Shielding Material
Length
30 cm
Plated Connector
Nickel
Coiled
White
Connector
4 pin USB Type A - male
Apple Lightning - male
RoHS
