StarTech.com 18in SATA to Left Side Angle SATA Serial ATA Cable
Quicklinx: 8GTTWS00 Mfr#: SATA18LSA1
Make a left side-angled connection to your SATA drive, for installation in narrow spaces. The SATA18LSA1 Left Side-Angled SATA Cable (18-inch) features one straight and one left side-angled (7-pin) data receptacle, which positions the cable so that it runs parallel to the drive ports - ideal for connectivity in narrow spaces, enabling installation of the drive as needed within the system case.
The cable also features a flexible low profile design that helps improve airflow and reduce clutter in your computer case, which helps keep the case clean and cool.
Constructed of only top quality materials and designed for optimum performance and reliability this 18" SATA cable supports full SATA 3.0 bandwidth (up to 6Gbps) when used with SATA 3.0 compliant drives.
StarTech.com SATA to Left Side Angle SATA Serial ATA Cable - SATA cable - 45.72 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Left-angled connector
Length
45.72 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
American Wire Gauge (AWG)
26
Length
45.72 cm
Red
Connector
RoHS
8GTT StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
