A space-saving, latching right angle SATA hard drive cable, for installations in tight spaces. The LSATA18RA2 Right Angle (90-degree) SATA Cable enables you to plug in your SATA hard drive in hard to reach areas or tight spaces, using right-angled SATA connectors to reduce the amount of space required at the connection point and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
- StarTech.com Right Angle Latching SATA Serial ATA Cable - SATA cable - 46 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300
- 90° connector, right-angled connector
- Length
- 46 cm
- Connector
- 7 pin Serial ATA - female
- Connector (Second End)
- Red
- Limited lifetime warranty
- Designed For
- P/N: BRACKET25X2, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB2535SATBK, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PEXSAT32, USB2SATAIDE, USB3SSATAIDE
- Storage Cable Type
- SATA cable
- Interface Speed
- Length
- 46 cm
- Red
- Connector
- Designed For
