StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p
Quicklinx: F2GHWS00 Mfr#: RKCOND17HD
Product Type: Rackmount Console
£927.37 ex VAT
£1,112.84 inc VAT
Providing centralized control of your single PC or dozens of servers, this dual rail rackmount KVM console also gives you easy access to and visibility of your system while it's mounted in a server rack or cabinet.
The dual rail KVM console design maximizes space in your datacenter's rack cabinets by allowing the LCD monitor and the keyboard/mouse to move separately from each other. You can tuck the keyboard away while the display stays active, allowing you to conveniently monitor your computer through closed glass or mesh rack cabinet doors.
The 1080p KVM console is 17.3" and LED back-lit, for low power consumption. It supports high definition resolutions up to 1920x1080 providing sharper video performance.
Whether you are running a multi-port KVM with an analog display or a single port KVM with a high definition display, this DVI/ VGA KVM console can support both signals.
This KVM console comes with everything you need to set up: 1 Audio Cable; 1 Set of KVM Cables (USB/VGA); 2 Rear Mounting Brackets; M5 Cage Nuts and Screws.
Once your KVM console is mounted to your rack, you can use the USB port on the front to easily connect any USB compatible peripheral such as a fingerprint scanner or mouse thumb drive.
StarTech.com offers a wide selection of KVM consoles to help you access your systems more efficiently without the expense and clutter of extra peripherals.
  • High-resolution display
    The 17.3-inch screen features a native resolution of 1920 x 1080, delivering crisp and vivid visuals that enhance user interaction.
  • Versatile connectivity
    Equipped with dual DVI-D and VGA inputs, this KVM console provides flexible interfacing options for various systems.
  • Robust image quality
    With an image brightness of 250 cd/m2 and a contrast ratio of 650:1, users experience clear and detailed images across varying lighting conditions.
  • Efficient space usage
    The rack-mountable form factor ensures efficient utilization of space while maintaining accessibility to critical components.
  • Long operational lifespan
    Designed for reliability, the KVM console has an MTBF of 44,230 hours, making it suitable for demanding environments.
StarTech.com Dual Rail Rackmount KVM Console HD 1080p, Single Port DVI/VGA KVM with 17" LCD Monitor for Server Rack, Fully Featured 1U LCD KVM Drawer with Cables, USB Support, 44230 MTBF - Single Port Console (RKCOND17HD) - KVM console - Full HD (1080p) - 17.3"
KVM console - 17.3"
KVM Switch
USB - 1 ports
Keyboard, touchpad
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.199 mm
Brightness
250 cd/m²
Contrast Ratio
650:1
Colour Support
262,144 colours
Input Connectors
2xDVI-D, 2xVGA
Voltage
AC 120/230 V
48 cm x 72.7 cm x 4.4 cm
Height (Rack Units)
1U
12 kg
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
UL, FCC, RoHS
Display Type
KVM console / TFT active matrix
Diagonal Size
17.3"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.199 mm
Brightness
250 cd/m²
Contrast Ratio
650:1
Colour Support
262,144 colours
Horizontal Viewing Angle
140
Vertical Viewing Angle
120
Height (Rack Units)
1U
12 kg
Input
Keyboard, touchpad
KVM
KVM switch - 1 ports
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1080 @ 60 Hz
VGA output , 2 x USB 2.0 (Type A) , DVI-D output , Audio line-out (mini-jack) , VGA , DVI-D , USB 2.0 (Type B) , Audio line-in (mini-jack)
LED indicator
Firmware upgrade cable, 8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
1 x keyboard / mouse / video cable - 1.2 m , 1 x audio cable - 1.8 m
Rack Mounting Kit
Included
MTBF
44230 hour(s)
UL, FCC, RoHS
Input Voltage
AC 120/230 V
Power Consumption (Typical)
19.4 Watt
10 - 80% (non-condensing)
F2GH StarTech.com 6 ft 2-in-1 USB KVM Cable In Stock £8.74
F2GH StarTech.com 10 ft 2-in-1 Universal USB KVM Cable In Stock £12.47
F2GH StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.80
F2GH StarTech.com 15 ft 2-in-1 Universal USB KVM Cable In Stock £17.46
F2GH StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
F2GH StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £2.97
F2GH StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
F2GH StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £1,162.96
F2GH StarTech.com Single Server KVM Console for Server Rack -19" In Stock £749.12
F2GH StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,320.56
F2GH StarTech.com Single Port Server KVM console with KVM Switch In Stock £655.56
F2GH StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor In Stock £1,019.95
F2GH StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor In Stock £1,110.82
F2GH StarTech.com 1U HD Single Server KVM In Stock £803.46
Price Range Ex VAT: £750 - £1000
