StarTech.com 1U HD Single Server KVM
Quicklinx: F2KQWS00 Mfr#: RKCONS17HD
Type: KVM switch
Connectivity: HDMI
Ports: 1
£803.46 ex VAT
£964.15 inc VAT
Control your server or KVM switch from a centralized HD KVM console. Providing centralized control of your single PC or dozens of servers, this HD rackmount KVM console also gives you easy access to and visibility of your system while it's mounted in a server rack or cabinet. Connected to your servers through a separate KVM switch (sold separately), the LCD console installs into 1U of rack-space, offering a space-efficient solution for complete console control.
The 1080p KVM console's monitor is 17.3" and LED back-lit, for low power consumption. It supports high-definition resolutions up to 1920x1080 providing sharper video performance. This HD console also provides more screen space, helping you to run multiple applications on the same screen, increasing your productivity.
The rack-mount LCD console slides out from 1U of rack space, enabling you to easily monitor and control a single server or multiple servers when connected through a KVM switch. The rackmount VGA KVM features a handle that makes it easy to slide the console in and out of the server rack, keeping your area organized and clutter-free.
This single-port KVM console comes with everything you need to set up: 1 Audio Cable; 1 Set of KVM Cables (VGA); 2 Rear Mounting Brackets; M5 Cage Nuts and Screws.
This KVM console provides all the essential controls you'll need to manage your server room at a low cost. The console features a built-in keyboard and a touchpad for intuitive control, as well as a high-definition LCD display.
StarTech.com offers a wide selection of KVM consoles to help you access your systems more efficiently without the expense and clutter of extra peripherals.
  • High resolution display
    The console features a native resolution of 1920 x 1080 ensuring clear visuals for better monitoring and management.
  • Durable construction
    Featuring a mean time between failures (MTBF) of 50,000 hours, this console is built for extensive use.
  • Versatile connectivity
    The KVM console supports USB keyboard and mouse interfaces and comes with a VGA connection for video input.
  • Efficient design
    With 13 watts of power consumption, this console offers energy-efficient operation for data center environments.
  • Environmental compliance
    The product meets standards including UL, FCC, RoHS, and PSE Mark, ensuring environmental safety.
StarTech.com Rackmount KVM Console HD 1080p, Single Port VGA KVM with 17" LCD Monitor for Server Rack, Fully Featured 1U LCD KVM Drawer with Cables & Hardware, USB Support, 50,000 MTBF - 17in. LCD KVM Console (RKCONS17HD) - KVM console - Full HD (1080p) - 17.3"
KVM console - 17.3"
KVM Switch
USB - 1 ports
Keyboard, touchpad
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1989 mm
Brightness
300 cd/m²
Contrast Ratio
800:1
Colour Support
262,144 colours
Input Connectors
VGA
Voltage
AC 120/230 V
48.3 cm x 56.5 cm x 4.3 cm
Height (Rack Units)
1U
13.7 kg
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
UL, FCC, RoHS, PSE Mark
Display Type
KVM console / TFT active matrix
Diagonal Size
17.3"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1989 mm
Brightness
300 cd/m²
Contrast Ratio
800:1
Colour Support
262,144 colours
Horizontal Viewing Angle
170
Vertical Viewing Angle
170
Height (Rack Units)
1U
13.7 kg
Input
Keyboard, touchpad
KVM
KVM switch - 1 ports
Keyboard / Mouse Interface
USB
Max Resolution
1080p @ 60 Hz
VGA
LED indicator
8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
1 x keyboard / mouse / video cable - 1.8 m
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
Input Voltage
AC 120/230 V
Power Consumption (Typical)
13 Watt
Shipping Weight
16 kg
10 - 80% (non-condensing)
F2KQ StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
F2KQ StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
F2KQ StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £524.78
F2KQ StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
F2KQ StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
F2KQ StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £1,162.96
F2KQ StarTech.com Single Server KVM Console for Server Rack -19" In Stock £785.17
F2KQ StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,320.56
F2KQ StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p In Stock £927.37
F2KQ StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor In Stock £999.35
F2KQ StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor In Stock £1,110.82
F2KQ StarTech.com 1U HD Single Server KVM In Stock £803.46
F2KQ StarTech.com 10 ft. (3 m) USB KVM Cable for Rackmount Consoles In Stock £30.11
F2KQ StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles In Stock £40.34
F2KQ StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles In Stock £17.59
Type: KVM switch
Connectivity: HDMI
Ports: 1
Price Range Ex VAT: £750 - £1000
