Providing centralized control of your single PC or dozens of servers, this dual rail rackmount KVM console also gives you easy access to and visibility of your system while it's mounted in a server rack or cabinet.
The dual rail KVM console design maximizes space in your datacenter's rack cabinets by allowing the LCD monitor and the keyboard/mouse to move separately from each other. You can tuck the keyboard away while the display stays active, allowing you to conveniently monitor your computer through closed glass or mesh rack cabinet doors.
The 1080p KVM console is 17.3" and LED back-lit, for low power consumption. It supports high definition resolutions up to 1920x1080 providing sharper video performance.
Whether you are running a multi-port KVM with an analog display or a single port KVM with a high definition display, this DVI/ VGA KVM console can support both signals.
This KVM console comes with everything you need to set up: 1 Audio Cable; 1 Set of KVM Cables (USB/VGA); 2 Rear Mounting Brackets; M5 Cage Nuts and Screws.
Once your KVM console is mounted to your rack, you can use the USB port on the front to easily connect any USB compatible peripheral such as a fingerprint scanner or mouse thumb drive.
StarTech.com offers a wide selection of KVM consoles to help you access your systems more efficiently without the expense and clutter of extra peripherals.
- StarTech.com Dual Rail Rackmount KVM Console HD 1080p, Single Port DVI/VGA KVM with 17" LCD Monitor for Server Rack, Fully Featured 1U LCD KVM Drawer with Cables, USB Support, 44230 MTBF - Single Port Console (RKCOND17HD) - KVM console - Full HD (1080p) - 17.3"
- KVM console - 17.3"
- KVM Switch
- USB - 1 ports
- Keyboard, touchpad
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.199 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 650:1
- Colour Support
- 262,144 colours
- Input Connectors
- 2xDVI-D, 2xVGA
- Voltage
- AC 120/230 V
- Black
- 48 cm x 72.7 cm x 4.4 cm
- Height (Rack Units)
- 1U
- 12 kg
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- UL, FCC, RoHS
- 2-year warranty
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17.3"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.199 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 650:1
- Colour Support
- 262,144 colours
- Horizontal Viewing Angle
- 140
- Vertical Viewing Angle
- 120
- Black
- 1U
- 12 kg
Input
KVM
- KVM switch - 1 ports
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1080 @ 60 Hz
- VGA output , 2 x USB 2.0 (Type A) , DVI-D output , Audio line-out (mini-jack) , VGA , DVI-D , USB 2.0 (Type B) , Audio line-in (mini-jack)
- LED indicator
- Included Accessories
- Firmware upgrade cable, 8 x M5 cage nuts, 8 x M5 screws, 2 x mounting rails
- Cables Included
- 1 x keyboard / mouse / video cable - 1.2 m , 1 x audio cable - 1.8 m
- Rack Mounting Kit
- Included
- MTBF
- 44230 hour(s)
- UL, FCC, RoHS
- Localisation
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 19.4 Watt
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
StarTech.com 6 ft 2-in-1 USB KVM Cable | In Stock | £7.02 |
StarTech.com 10 ft 2-in-1 Universal USB KVM Cable | In Stock | £12.51 |
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.52 |
StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone | In Stock | £10.67 |
StarTech.com 15 ft 2-in-1 Universal USB KVM Cable | In Stock | £17.60 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.99 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.26 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.79 |
StarTech.com 8 Port KVM Console for Server Rack - 19in | In Stock | £1,187.53 |
StarTech.com Single Server KVM Console for Server Rack -19" | In Stock | £750.49 |
StarTech.com 16 port KVM VGA Console with KVM Switch - 19" | In Stock | £1,303.52 |
StarTech.com Single Port Server KVM console with KVM Switch | In Stock | £658.96 |
StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p | In Stock | £942.18 |
StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor | In Stock | £1,019.51 |
StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor | In Stock | £1,250.88 |
StarTech.com 1U HD Single Server KVM | In Stock | £799.21 |
