This Laptop Privacy Screen is compatible with the 2021 and 2023 16-inch MacBook Pro laptop computers. Gold Privacy Filters have a reflective surface that instantly transitions from a clear view to a mirror effect outside of the intended viewing angle, significantly improving visual privacy when working in an office or public environment.
Prevent Visual Eavesdropping
The gold security filter is a convenient solution that features a quick shift to a mirror-like effect to protect confidential data from unwanted viewers while maintaining a clear view of 60 degrees (+/- 30 degrees from the center) for the user. -
Double-Sided Filter
The security screen protector features a glossy gold side for maximum privacy and an anti-glare matte side for environments prone to glare. The matte side provides additional screen protection with a scratch- and fingerprint-resistant coating. -
Hassle-free Installation
The filter is an exact fit design that will not interfere with top-mounted webcams, sensors around the display, or when closing the lid. Affix the privacy screen shield using the included transparent and residue-free adhesive strips. -
Blue Light Reduction
Reduce eye strain and improve visual comfort with this blue light-reducing privacy shield. It blocks 40% - 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
- StarTech.com 16-inch MacBook Pro 21/23 Privacy Screen, Gold Filter w/Enhanced Privacy, Computer Security Shield, Double-Sided Screen Protector, +/- 30 Deg. - notebook privacy filter (horizontal)
- Product Type
- Notebook privacy filter (horizontal)
- Installation Type
- Removable - adhesive
- Package Content
- Adhesive strip, wiping cloth
- Black, gold
- Product Material
- Plastic
- 35.1 cm x 22.9 cm
- 100 g
- Display Screen Size Compatibility
- 16"
- +/- 30° visible angle, 51% blue light reduction
- 2-year warranty
- Product Type
- Product Material
- Plastic
- Package Content
- 35.1 cm
- 22.9 cm
- Thickness
- 0.5 mm
- 100 g
- Shipping Dimensions (WxDxH) / Weight
- 39 cm x 24.5 cm x 0.6 cm / 218 g
- 16"
- Black, gold
Display Filter
- Installation Type
- Scratch Resistant
- Mounting Kit
- Included
- Limited warranty: - 2 years
StarTech.com Privacy Screen Adhesive Strips | In Stock | £6.33 |
StarTech.com 14in MacBook Privacy Screen | In Stock | £33.79 |
StarTech.com 16in MacBook Privacy Screen
