StarTech.com 14in MacBook Privacy Screen
Quicklinx: HKKCWS00 Mfr#: 142MG-PRIVACY-SCREEN
Device Type: Macbook
Type: Privacy Screen
Device Screen Size: 14
Colour: Black, Gold
£32.46 ex VAT
£38.95 inc VAT
This laptop privacy screen is compatible with the 2021 and 2023 14" MacBook Pro laptops.
Prevent Visual Eavesdropping
This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your MacBook's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
Reversible Filter
The privacy screen protector is reversible, with a matte anti-glare side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint and scratch resistant coating. The privacy shield has a light transmittance of 57.5% providing optimal screen brightness and enhanced levels of privacy.
Hassle-free Installation
The privacy filter is an exact fit design that will not interfere with top-mounted webcams, sensors, or when closing the lid. Affix the privacy screen shield using the included transparent and residue-free adhesive strips.
Blue Light Reduction
Reduce eye strain and improve visual comfort with this blue light reducing privacy shield. It blocks up to 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
  • Prevent visual eavesdropping
    The gold security filter is a convenient solution that features a quick shift to a mirror-like effect to protect confidential data from unwanted viewers while maintaining a clear view of 60 degrees (+/- 30 degrees from the center) for the user.
  • Double-sided filter
    The security screen protector features a glossy gold side for maximum privacy and an anti-glare matte side for environments prone to glare. The matte side provides additional screen protection with a scratch- and fingerprint-resistant coating.
  • Hassle-free installation
    The filter is an exact fit design that will not interfere with top-mounted webcams, sensors around the display, or when closing the lid. Affix the privacy screen shield using the included transparent and residue-free adhesive strips.
  • Blue light reduction
    Reduce eye strain and improve visual comfort with this blue light-reducing privacy shield. It blocks 40% - 51% of the blue light emitted from the display in the 380 nm - 480 nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 14-inch MacBook Pro 21/23 Privacy Screen, Gold Filter w/Enhanced Privacy, Computer Security Shield, Double-Sided Screen Protector, +/- 30 Deg. - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal)
Installation Type
Removable - adhesive
Package Content
Adhesive strip, wiping cloth
Black, gold
Product Material
Plastic
35.1 cm x 22.8 cm
90 g
Display Screen Size Compatibility
14"
Fingerprint-resistant coating, +/- 30° visible angle, 51% blue light reduction
Product Material
Plastic
Package Content
35.1 cm
22.8 cm
Thickness
0.5 mm
90 g
39 cm x 4.3 cm x 0.6 cm / 200 g
14"
Black, gold
Display Filter
Installation Type
Scratch Resistant
Mounting Kit
Included
Limited warranty: - 2 years
HKKC StarTech.com Privacy Screen Adhesive Strips In Stock £6.98
HKKC StarTech.com 16in MacBook Privacy Screen In Stock £32.66
Colour: Black
Colour: Gold
