StarTech.com 16in MacBook Privacy Screen
Quicklinx: HKKJWS00 Mfr#: 162MG-PRIVACY-SCREEN
£33.48 ex VAT
£40.17 inc VAT
This Laptop Privacy Screen is compatible with the 2021 and 2023 16-inch MacBook Pro laptop computers. Gold Privacy Filters have a reflective surface that instantly transitions from a clear view to a mirror effect outside of the intended viewing angle, significantly improving visual privacy when working in an office or public environment.
  • Prevent Visual Eavesdropping
    The gold security filter is a convenient solution that features a quick shift to a mirror-like effect to protect confidential data from unwanted viewers while maintaining a clear view of 60 degrees (+/- 30 degrees from the center) for the user.
  • Double-Sided Filter
    The security screen protector features a glossy gold side for maximum privacy and an anti-glare matte side for environments prone to glare. The matte side provides additional screen protection with a scratch- and fingerprint-resistant coating.
  • Hassle-free Installation
    The filter is an exact fit design that will not interfere with top-mounted webcams, sensors around the display, or when closing the lid. Affix the privacy screen shield using the included transparent and residue-free adhesive strips.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort with this blue light-reducing privacy shield. It blocks 40% - 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 16-inch MacBook Pro 21/23 Privacy Screen, Gold Filter w/Enhanced Privacy, Computer Security Shield, Double-Sided Screen Protector, +/- 30 Deg. - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal)
Installation Type
Removable - adhesive
Package Content
Adhesive strip, wiping cloth
Black, gold
Product Material
Plastic
35.1 cm x 22.9 cm
100 g
Display Screen Size Compatibility
16"
+/- 30° visible angle, 51% blue light reduction
Product Material
Plastic
Package Content
35.1 cm
22.9 cm
Thickness
0.5 mm
100 g
39 cm x 24.5 cm x 0.6 cm / 218 g
16"
Black, gold
Display Filter
Installation Type
Scratch Resistant
Mounting Kit
Included
Limited warranty: - 2 years
