StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate
Quicklinx: 76PJWS00 Mfr#: PLATE9M16
Length: 41cm
More than 50 in stock
£3.28 ex VAT
£3.93 inc VAT
This 9-pin Serial to 10-pin Header Slot Plate adapter features one DB9 male connector and one IDC10 connector. The adapter is constructed of high quality components and expertly designed to ensure durability and reliability.
Please refer to the Technical Specifications to ensure your motherboard is compatible with this product.
StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate - motherboard Serial Port Adapter (PLATE9M16) - serial panel - DB-9 to 10 PIN IDC - 41 cm
Serial panel
Length
41 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
10 PIN IDC - female
Grey
Serial panel
Length
41 cm
Grey
Connector
10 PIN IDC - female
RoHS
76PJ StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header LP Slot Plate In Stock £3.07
76PJ StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate In Stock £3.28
Length: 41cm
Stock Status: In stock
