StarTech.com 2 Port 16in DB9 Serial Port Bracket to 10 Pin Header
Quicklinx: 84NZWS00 Mfr#: PLATE9M2P16
£6.24 ex VAT
£7.48 inc VAT
Add two extra serial ports to the back of your PC, from your motherboard. The PLATE9M2P16 Dual Port Serial Plate adds two DB9 serial ports to the rear panel of a computer, connecting to two IDC10 header connectors on the motherboard.
Please refer to this product's Technical Specifications to ensure compatibility with your motherboard.
StarTech.com 2 Port 16in DB9 Serial Port BRacket to 10 Pin Header - DB9 bRacket - DB9 Header - Serial Port bRacket (PLATE9M2P16) - serial panel - DB-9 to 10 PIN IDC - 40.64 cm
Serial panel
Length
40.64 cm
Connector
2 x 9 pin D-Sub (DB-9) - male
Connector (Second End)
2 x 10 PIN IDC - female
Grey
Serial panel
American Wire Gauge (AWG)
28
Length
40.64 cm
Grey
Connector
RoHS
84NZ StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header LP Slot Plate In Stock £4.48
84NZ StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate In Stock £5.60
