StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate
Quicklinx: 76PJWS00 Mfr#: PLATE9M16
Length: 41cm
Type: Motherboard
11 In Stock
£5.74 ex VAT
£6.88 inc VAT
This 9-pin Serial to 10-pin Header Slot Plate adapter features one DB9 male connector and one IDC10 connector. The adapter is constructed of high quality components and expertly designed to ensure durability and reliability.
Please refer to the Technical Specifications to ensure your motherboard is compatible with this product.
  • Versatile Connectivity
    The adapter features a 9-pin D-Sub (DB-9) male connector alongside a 10 pin IDC female connector, allowing for versatile connections between various devices and motherboard headers.
  • Environmentally Compliant
    This product conforms to RoHS standards, highlighting its eco-friendly design that complies with regulations aimed at reducing harmful substances in electronic products.
  • Flexible Installation
    With its 16 in (40 cm) cable length, this adapter offers flexibility that simplifies installation in systems with limited space or various configurations.
StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate - motherboard Serial Port Adapter (PLATE9M16) - serial panel - DB-9 to 10 PIN IDC - 41 cm
Serial panel
Length
41 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
10 PIN IDC - female
Grey
Serial panel
Length
41 cm
Grey
Connector
10 PIN IDC - female
RoHS
76PJ StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header LP Slot Plate In Stock £4.53
76PJ StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate In Stock £5.74
76PJ StarTech.com 1 Port 16in DB9 Serial Port Bracket to 10 Pin Header - Low Profile In Stock £5.36
76PJ StarTech.com 2 Port 16in DB9 Serial Port Bracket to 10 Pin Header In Stock £5.96
Length: 41cm
Type: Motherboard
