StarTech.com 16 port KVM VGA Console with KVM Switch - 19"
Quicklinx: DLKGWS00 Mfr#: RKCONS1916K
Type: KVM switch
Connectivity: VGA
Ports: 16
£1,288.35 ex VAT
£1,546.02 inc VAT
This 1U 16-port KVM console provides complete keyboard, monitor and mouse control for 16 computers. The rack-mount console installs into 1U of rack space, offering a space-efficient solution for complete console control.
  • Maximize your IT budget, minimize your hassle
    This 16-port KVM switch provides all the essential controls you'll need to manage your server room at a low cost. The console features a built-in touchpad, keyboard for intuitive control and an LCD display that supports resolutions up to 1280x1024.
  • Maximize your screen space
    The increased screen space enables you to run multiple applications on the same screen, maximizing your productivity.
  • Clutter-free monitoring
    The console slides out from 1U of rack space, enabling you to easily monitor and control 16 servers, and even more if connecting through a KVM switch. The rack-mount VGA console features a handle for easy sliding in and out of the server rack, keeping your area organized and clutter-free.
  • Hassle-free system integration
    The rackmount LCD features a 16-port KVM module, allowing you to connect it directly to 16 servers. You can also connect to additional servers by connecting to KVM switches in a cascaded (daisy-chained) configuration. The KVM module offers the flexibility you need to easily integrate the console into your existing server infrastructure.
StarTech.com 16 Port Rackmount KVM Console with 6ft Cables, Integrated KVM Switch with 19" LCD Monitor, Fully Featured 1U LCD KVM Drawer- OSD KVM, Durable 50,000 MTBF, USB + VGA Support - 19in. LCD KVM Console (RKCONS1916K) - KVM console - 19"
KVM console - 19"
KVM Switch
PS/2, USB - 16 ports
Keyboard Layout
US
Daisy Chaining
Keyboard, touchpad, 16 port KVM switch
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
VGA
48.3 cm x 64.3 cm x 4.3 cm
Height (Rack Units)
1U
13.5 kg
Australia, Japan, New Zealand, North America, United Kingdom, Europe
UL, FCC, RoHS, WEEE, PSE Mark, RCM
Display Type
KVM console / TFT active matrix
Diagonal Size
19"
Daisy Chaining
Built-in Devices
16 port KVM switch
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Height (Rack Units)
1U
13.5 kg
Input
Keyboard, touchpad
KVM
KVM switch - 16 ports
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1280 x 1024
2 x VGA , 2 x USB 2.0 , 16 x KVM , 2 x PS/2
8 x M5 cage nuts, 8 x M5 screws, 4 x mounting rails
16 x keyboard / mouse / video cable
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
DLKG StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £452.75
DLKG StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £273.74
DLKG StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £1,134.60
DLKG StarTech.com Single Server KVM Console for Server Rack -19" In Stock £730.86
DLKG StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,288.35
DLKG StarTech.com Single Port Server KVM console with KVM Switch In Stock £639.58
DLKG StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p In Stock £904.75
DLKG StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor In Stock £974.99
DLKG StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor In Stock £1,083.73
DLKG StarTech.com 1U HD Single Server KVM In Stock £783.87
DLKG StarTech.com 6 ft. (1.8 m) USB KVM Cable for Rackmount Consoles In Stock £17.16
Type: KVM switch
Connectivity: VGA
Ports: 16
Price Range Ex VAT: £1000 - £1500
