Create feature-rich HDMI connections, up to 15 m away with no signal loss. This CL2 HDMI cable is rated for in-wall installations. It also has a built-in active signal booster that allows for a connection distance of up to 50 feet (15 m) between your HDMI devices, with no signal loss. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
The cable's built-in amplifier circuitry actively boosts the HDMI signal with no external power required. It supports longer connections than regular HDMI. The active cable also features a thinner wire construction for more flexibility, making it ideal for in-wall installations.
This 4K HDMI cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors.
With higher resolutions, increased speeds, and sharper images, the cable provides the very best HDMI capabilities available today. It's the perfect cable for creating the ultimate home-theater experience, for providing lifelike digital signage, or for delivering exceptional presentations.
The cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound.
Reliable and high-quality connection
Featuring male 19-pin HDMI Type-A connectors on each end, this cable provides a secure and dependable connection to compatible devices, minimizing signal loss. -
Enhanced signal transmission
The built-in amplifier within the cable ensures excellent signal integrity, allowing it to perform effectively even over longer lengths like 15 m. -
Safe for installations
With a CL2 rated jacket, this cable can be safely installed within walls, adhering to building codes while providing versatile connectivity options. -
Vibrant and rich visuals
HDR support optimizes the viewing experience by delivering enhanced color depth and contrast for more lifelike images. -
Versatile compatibility
This HDMI cable is designed to work with a wide range of devices, ensuring seamless connectivity for televisions, projectors, and other AV equipment.
- StarTech.com 15m(50ft) HDMI 2.0 Cable, 4K 60Hz Active HDMI Cable, CL2 Rated for In Wall Installation, Long Durable High Speed Ultra-HD HDMI Cable, HDR 10, 18Gbps, Male to Male Cord, Black - Al-Mylar EMI Shielding (HD2MM15MA) - HDMI cable - 15 m
- Cable
- HDMI cable
- Length
- 15 m
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- 4K support
- 2-year warranty
- Designed For
- P/N: ST122HD202, ST124HD202
- Cable Type
- HDMI cable 4K support
- Length
- 15 m
- CL2 rated jacket, HDR support, built-in amplifier
- Connector
- 19 pin HDMI Type A - male
- Limited warranty - 2 years
- Designed For
StarTech.com 10m CL2 Active HDMI Cable - 4K | In Stock | £78.22 |
StarTech.com 15m CL2 Active HDMI Cable - 4K | In Stock | £93.94 |
StarTech.com Active HDMI 2.0 Cable | In Stock | £142.66 |
StarTech.com Active HDMI 2.0 Cable | In Stock | £172.58 |
