The cable's built-in amplifier circuitry actively boosts the HDMI signal with no external power required. It supports longer connections than regular HDMI. The active cable also features a thinner wire construction for more flexibility, making it ideal for in-wall installations.
This 4K HDMI cable supports resolutions of up to 4K@60Hz (3840 x 2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors.
Create 4K HDMI connections over longer distances
The cable's built-in amplifier circuitry actively boosts the HDMI signal with no external power required. It supports longer connections than regular HDMI. The active cable also features a thinner wire construction for more flexibility, making it ideal for in-wall installations. -
Experience the best that HDMI has to offer
- StarTech.com 10m(30ft) HDMI 2.0 Cable, 4K 60Hz Active HDMI Cable, CL2 Rated for In Wall Installation, Long Durable High Speed Ultra-HD HDMI Cable, HDR 10, 18Gbps, Male to Male Cord, Black - Al-Mylar EMI Shielding (HD2MM10MA) - HDMI cable - 10 m
- Cable
- HDMI cable
- Length
- 10 m
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- 4K support
- 2-year warranty
- Designed For
- P/N: ADJPROJCART, FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWHANGER, FPWTLTBAT, FPWTLTPORT, MBLTVSTNDEC, ST122HD202, ST124HD202, STNDMTV100, STNDMTV70, STNDMTVDUO
- Cable Type
- HDMI cable 4K support
- Length
- 10 m
- CL2 rated jacket, HDR support, built-in amplifier
- Connector
- 19 pin HDMI Type A - male
- Limited warranty - 2 years
- Designed For
