StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black
Quicklinx: 92P9WS00 Mfr#: DP2VGAMM15B
Length: 4.57m
£25.49 ex VAT
£30.58 inc VAT
Connect a DisplayPort-equipped PC to a VGA monitor/projector, with a 15ft long cable. The DP2VGAMM15B 15ft active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector at a longer distance than a standard-length cable would support, while saving the expense of additional adapters.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 15 ft DisplayPort to VGA Adapter Cable - DP to VGA Video Converter - Active DisplayPort to VGA Cable for PC 1920x1200 - Black (DP2VGAMM15B) - DisplayPort cable - 4.57 m
DisplayPort cable
Latched
Length
4.57 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
FCC, RoHS
3-year warranty
DisplayPort cable
Latched
Length
4.57 m
Connector
20 pin DisplayPort - male
FCC, RoHS
3-year warranty
92P9 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £24.00
92P9 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £15.81
92P9 StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £20.60
92P9 StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £8.14
92P9 StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £20.09
92P9 StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £22.31
92P9 StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £23.78
92P9 StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £25.49
92P9 StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.47
92P9 StarTech.com DP to VGA Adapter with Audio In Stock £23.69
92P9 StarTech.com DisplayPort to VGA Adapter - 1920x1200 In Stock £70.85
Length: 4.57m
