StarTech.com 12U Wall-Mount Server Rack
Quicklinx: D5BLWS00 Mfr#: RK12WALLOA
£102.53 ex VAT
£123.03 inc VAT
Mount your server or networking equipment to the wall, using this adjustable 12U open frame rack. This open-frame wall-mount server rack provides 12U of storage, helping you to save space and stay organized. The equipment rack features an adjustable depth and can hold a total of up to 198 lb. (90 kg).
With adjustable depth to as low as 12 in. (30.4 cm) this network rack is perfect for smaller spaces. It's easy to assemble and features wall-mounting holes that are spaced 12 and 16 in. apart, making it suitable for mounting on almost any wall, based on North American wall-frame stud-spacing standards. The wall-mount rack comes in a flat-pack, which makes it easy to transport and saves you money on shipping.
The open-frame rack adjusts from 12 to 20 in. (30.4 to 50.8 cm) to accommodate larger data, network, and telecommunication devices. The above-average depth also gives you the option to mount shelves and other accessories.
When space is limited you can mount the open-frame rack on a server room wall, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access.
The rack's open frame design ensures passive cooling for your rack-mounted equipment. Additionally, the open frame provides easy access to your equipment and makes it easier to configure mounted devices, which saves you time.
  • Easy, hassle-free installation
  • Accommodate larger devices
  • Free up space
  • Keep your equipment cool and accessible
    The rack's open frame design ensures passive cooling for your rack-mounted equipment. Additionally, the open frame provides easy access to your equipment and makes it easier to configure mounted devices, which saves you time. The RK12WALLOA is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com 12U 19" Wall Mount Network Rack, Adjustable Depth 12-20" 2 Post Open Frame Server Room Rack for AV/Data/ IT Communication/Computer Equipment/Switch with Cage Nuts & Screws - 12U Adjustable Rack (RK12WALLOA) - rack - 12U
Rack
Placing / Mounting
Wall mountable
Package Content
48 M6 cage nuts, 48 M6 screws, 2 vertical rails, 2 front horizontal brackets, 2 rear horizontal brackets, 48 plastic washers, 16 assembly screws, 24 flat washers, 24 bolts
Rack Size
20"
Height (Rack Units)
12U
Product Material
Steel
50.4 cm x 30.5 cm x 64.1 cm
16 kg
Adjustable depth, 2 post
5-year warranty
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Rack Size
20"
Height (Rack Units)
12U
50.4 cm
30.5 cm
64.1 cm
16 kg
Inner Dimensions
45 cm x 29.2 cm x 53.4 cm
Weight Limit
90 kg
Limited warranty: - 5 years
D5BL StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
D5BL StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
D5BL StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
D5BL StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
D5BL StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
D5BL StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
D5BL StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.68
D5BL StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
D5BL StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
D5BL StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
D5BL StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
D5BL StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £24.18
D5BL StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
D5BL StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
D5BL StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
D5BL StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
D5BL StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
D5BL StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
D5BL StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
D5BL StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
D5BL StarTech.com 19in Cable Management Panel In Stock £24.18
D5BL StarTech.com 12U Wall Mount Server Rack In Stock £66.02
D5BL StarTech.com 15U Wall Mount Server Rack In Stock £76.82
D5BL StarTech.com 15U Wall-Mount Server Rack In Stock £113.87
D5BL StarTech.com 12U Wall-Mount Server Rack In Stock £102.53
D5BL StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
D5BL StarTech.com 18U Open Frame Equipment Rack In Stock £167.37
D5BL StarTech.com 21U Open Frame Equipment Rack In Stock £160.86
D5BL StarTech.com 24U Open Frame Equipment Rack In Stock £192.58
