The RACK-21U-20-WALL-OA 21U Open Frame Wall Mount Equipment Rack with Adjustable Depth is a high-quality, sturdy relay rack solution that is easy to assemble and install into any environment.
Sturdy Construction & Easy Installation
The open rack features an adjustable depth ranging from 12-20 inches to accommodate larger data, network, and telecommunications devices. With a maximum depth of 20 inches, this rack allows for mounting of shelves and other accessories with enough clearance at the back for cable management. The open-frame design help to keep your equipment cool and easily accessible from different angles. The wall mounting holes are positioned 12 and 16 inches apart (center to center) providing a convenient and effecting anchoring, making it suitable for mounting on virtually any wall surface or construction framework. -
Includes Hardware
This 21U rack includes M6 square cage nuts and M6 screws to save you the hassle of sourcing separate mounting hardware for your equipment. This rack can be mounted to the wall in a server room, data closet, or office expanding your valuable floor space. The RACK-21U-20-WALL-OA is backed for 5-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 21U 19" Wall Mount Network Rack, Adjustable Depth 12-20" 2 Post Open Frame Server Room Rack for AV/Data/ IT Communication/Computer Equipment/Switch with Cage Nuts & Screws - 21U Adjustable Rack - rack - 21U
- Product Type
- Rack
- Rack Type
- Open frame - 2-post
- Placing / Mounting
- Wall mountable
- Package Content
- 2 front horizontal brackets, 2 rear horizontal brackets, 2 vertical brackets, 84 M6 cage nuts, 84 M6 cage screws, 84 plastic washers, 16 M5 x 12mm screws, 24 M8 x 16mm bolts, 24 #8 flat washers
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 21U
- Product Material
- SPCC cold rolled steel
- 50.4 cm x 50.8 cm x 100 cm
- 15.2 kg
- Adjustable depth 12" - 20", G-shaped mounting rail profile, square hole
- 5-year warranty
- Product Type
- Rack
- Rack Type
- Open frame
- Rack Post Qty
- 2-post
- Wall mountable
- Product Material
- Package Content
- Rack Size
- 19"
- 21U
- 50.4 cm
- 50.8 cm
- 100 cm
- 15.2 kg
- Shipping Dimensions (WxDxH) / Weight
- 43 cm x 120 cm x 17 cm / 20.2 kg
- Black
- Weight Limit
- 90 kg
- EIA-310-E, ECA-310-E, ISTA 6
- Limited warranty: - 5 years
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.71 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £15.50 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.68 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.36 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.59 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £47.16 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.75 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £23.11 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £58.68 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.63 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £9.55 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £53.55 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £28.25 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.56 |
StarTech.com 19in Cable Management Panel | In Stock | £24.18 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.56 |
StarTech.com 18U Open Frame Equipment Rack | In Stock | £167.37 |
StarTech.com 24U Open Frame Equipment Rack | In Stock | £192.58 |
