Mount your server or networking equipment using this 12U wall mount rack. This open-frame wall-mount server rack provides 12U of storage, allowing you to save space and stay organized. The equipment rack can hold up to 198 lb. (90 kg).
The network rack is 12 in. (30.4 cm) deep, so it's perfect for smaller spaces. It's easy to assemble and features mounting holes that are spaced 16 in. apart, making it suitable for mounting on almost any wall, based on common wall-frame stud spacing. The wall-mount rack comes in a flat-pack which makes it easy to transport and reduces shipping costs.
You can mount the open-frame rack where space is limited, such as on a server room wall, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access.
By having an open frame the server rack provides passive cooling to equipment. Additionally, the open frame provides easy access and configurability to your equipment, allowing you to maximize productivity.
Easy, hassle-free installation
The network rack is 12 in. (30.5 cm) deep, so it's perfect for smaller spaces. It's easy to assemble and features mounting holes that are spaced 16 in. apart, making it suitable for mounting on almost any wall, based on common wall-frame stud spacing. The wall-mount rack comes in a flat-pack which makes it easy to transport and reduces shipping costs. -
Free up space
You can mount the open-frame rack where space is limited, such as on a server room wall, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access. -
Keep your equipment cool and accessible
By having an open frame the server rack provides passive cooling to equipment. Additionally, the open frame provides easy access and configurability to your equipment, allowing you to maximize productivity. The RK12WALLO is backed by a StarTech.com 5-year warranty and free lifetime technical support.
- StarTech.com 12U 19" Wall Mount Network Rack - 12" Deep 2 Post Open Frame Server Room Rack for Data/AV/IT/Computer Equipment/Patch Panel with Cage Nuts & Screws 200lb Capacity, Black (RK12WALLO) - rack - 12U
- Product Type
- Rack
- Placing / Mounting
- Wall mountable
- Package Content
- 48 M6 cage nuts, 48 M6 screws, 2 vertical rails, 16 assembly screws, 48 washers, 2 horizontal brackets
- Black
- Rack Size
- 12"
- Height (Rack Units)
- 12U
- Product Material
- Steel
- 50.4 cm x 30.5 cm x 64.1 cm
- 10 kg
- 2 post
- 5-year warranty
- Product Type
- Rack
- Wall mountable
- Product Material
- Steel
- Package Content
- Rack Size
- 12"
- 12U
- 50.4 cm
- 30.5 cm
- 64.1 cm
- 10 kg
- Inner Dimensions
- 45 cm x 29.2 cm x 53.4 cm
- Black
- Weight Limit
- 90 kg
- 2 post
- Limited warranty: - 5 years
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.69 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £34.96 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.45 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.08 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.10 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £65.60 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £35.37 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.40 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £7.19 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £40.06 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £20.89 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £25.53 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £60.59 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £32.75 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £22.65 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £28.99 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £17.19 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £62.10 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £33.34 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £18.28 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £34.40 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £19.29 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £30.06 |
StarTech.com 19in Cable Management Panel | In Stock | £23.30 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £17.85 |
