StarTech.com 12U Office Server Cabinet w/ Wood Finish and Casters
Quicklinx: 9J59WS00 Mfr#: RKWOODCAB12
Depth (mm): 66cm
Width (mm): 56cm
Type: Floor standing
U Height: 12U
£628.47 ex VAT
£754.16 inc VAT
Store IT equipment discreetly in the office, with a stylish wood-finished server cabinet. The RKWOODCAB12 12U Office Server Cabinet lets you store your server, network or AV equipment discreetly in the office, with a stylish wood finish.
Designed to blend in with your office or boardroom furniture, this 12U server cabinet features wood laminate exterior panels with a shaded glass front window that keeps your equipment visible for monitoring, as well as front and rear key-locks to prevent unauthorized access. To help keep your valuable equipment running cooler, we've included a ventilation panel to maximize airflow. The cabinet also features durable casters, so that positioning your server equipment as needed isn't a hassle.
The 4-post enclosed rack supports a weight capacity of up to 300lbs (136kg) and offers rails with adjustable mounting depth from 16.7in (423mm) to 20.6in (523mm) to accommodate various sizes of equipment. Making it easy to route your cables where you need them, the 12U cabinet offers cable grommets on the rear and top panels, and a cable entry panel at the base.
StarTech.com "12U AV Rack Cabinet - 21? Deep - Wood Finish - Floor Standing Enclosure for 19"" Audio Video Component, Server Room & Network Equipment (RKWOODCAB12)" - rack - 12U
Rack
Wood
Height (Rack Units)
12U
56 cm x 66 cm x 66.4 cm
Key lock, casters
Rack
Height (Rack Units)
12U
56 cm
66 cm
66.4 cm
Wood
Weight Limit
136.1 kg
Mounting Kit
Included
Key lock, casters
RoHS
Limited warranty: - 2 years
9J59 StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £488.55
9J59 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £84.93
9J59 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.34
9J59 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.51
9J59 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £31.10
9J59 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £335.92
9J59 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.45
9J59 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.56
9J59 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.09
9J59 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.23
9J59 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.89
9J59 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £284.45
9J59 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.76
9J59 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £635.38
9J59 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £101.34
9J59 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £63.29
9J59 StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.90
9J59 StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £366.90
9J59 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £33.04
9J59 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.48
9J59 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £52.08
9J59 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
9J59 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.36
9J59 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.45
9J59 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £39.94
9J59 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
9J59 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.96
9J59 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.35
9J59 StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £170.86
9J59 StarTech.com 1U Server Rack Panel In Stock £11.99
9J59 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £57.09
9J59 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.44
9J59 StarTech.com 25U 36in Server Rack Cabinet In Stock £720.42
9J59 StarTech.com 100 Pkg M5 Cage Nuts In Stock £26.80
9J59 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.46
9J59 StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.99
9J59 StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.59
9J59 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £54.01
9J59 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £29.06
9J59 StarTech.com 50 Pkg M5 Mounting Screws In Stock £16.04
9J59 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.99
9J59 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.75
9J59 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.29
9J59 StarTech.com 100 Pkg M6 Cage Nuts In Stock £28.49
9J59 StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £518.96
9J59 StarTech.com 19in Cable Management Panel In Stock £23.30
9J59 StarTech.com M6 Mounting Screws 50Pack In Stock £16.78
Depth (mm): 66cm
Width (mm): 56cm
U Height: 12U
Price Range Ex VAT: £500 - £750
