StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg
Quicklinx: 7NXFWS00 Mfr#: CABSHELF1U
Product Type: Rack shelf, Rack shelf
Hurry, only 1 left in stock!
£25.30 ex VAT
£30.36 inc VAT
The CABSHELF1U 1U (Black) Universal Fixed Server Rack Cabinet Shelf lets you add a compact fixed storage shelf to any standard 19-inch server rack or cabinet with front mount options. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 15kg (33lbs) of equipment - a perfect solution for storing small form non-rackmount equipment, tools, peripherals or accessories in your rack, to keep them readily accessible.
  • Sturdy construction
    Made from cold-rolled steel, this rack shelf provides strength and support for your equipment, ensuring longevity and reliability in demanding environments.
  • Space-efficient design
    With a height of just 1U, this shelf allows for an organized setup in server racks without occupying excessive vertical space.
  • Ample weight capacity
    Able to support up to 15 kg, this shelf is suitable for various devices, making it versatile for different server configurations.
StarTech.com 1U Server Rack Cabinet Shelf, 7in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure with Cage Nuts & Screws, 33lbs Weight Capacity - 1U Rack Shelf 7" Deep (CABSHELF1U) - rack shelf - 1U
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RK1219SIDEM, RK1233BKM, RK1236BKF, RK12OD2, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK819SIDEM, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
1U
Weight Limit
15 kg
Limited warranty: - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1219SIDEM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK819SIDEM, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
7NXF StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
7NXF StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
7NXF StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
7NXF StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
7NXF StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
7NXF StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
7NXF StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
7NXF StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
7NXF StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
7NXF StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £93.48
7NXF StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
7NXF StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
7NXF StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
7NXF StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
7NXF StarTech.com Vented 1U Rack Shelf - 7in In Stock £24.38
7NXF StarTech.com 1U Rack Shelf - 10in In Stock £25.16
7NXF StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.83
7NXF StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.05
7NXF StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.75
7NXF StarTech.com 1U Vented Shelf 12in In Stock £34.44
7NXF StarTech.com 1U Vented Shelf 20in In Stock £58.86
7NXF StarTech.com 2U Vented Shelf 14in In Stock £62.75
7NXF StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £58.55
