Wall Mount your Server or Networking Equipment Sideways, for Easy Access. The RK1219SIDEM Wall Mount/Side Mount Deep Open Frame Rack/Cabinet (12U, 19in Wide) lets you mount your servers, A/V or network equipment facing perpendicular to the wall for easy access to mounted devices and equipment. The cabinet/rack features open access to both the front and back of your devices, making it easy to adjust cabling, view LEDs and access configuration buttons as needed; plus, the nature of the sidemount configuration allows for deeper mounting depths than typical wallmount racks. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Constructed of high-quality SPCC cold-rolled steel, for strength and durability, the open frame equipment rack allows for maximum airflow while still supporting a maximum weight capacity of 159 kg (350 lbs). The wall mount rack also ships complete with all of the M5 screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
- StarTech.com 12U Wall Mount Rack - Sideways Wall Mount IT Equipment Rack - Open Frame Wall Mount Data Rack (RK1219SIDEM) - cabinet - 12U
- Product Type
- Cabinet
- Placing / Mounting
- Wall mountable
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 12U
- Product Material
- Steel
- 53.7 cm x 55.8 cm x 65.5 cm
- 21.8 kg
- Limited lifetime warranty
- Product Type
- Cabinet
- Wall mountable
- Product Material
- Steel
- Rack Size
- 19"
- 12U
- 53.7 cm
- 55.8 cm
- 65.5 cm
- 21.8 kg
- Black
- EIA-310-D, RoHS
- Limited warranty: - lifetime
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £66.84 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.90 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.91 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.44 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.39 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £27.99 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £52.23 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £55.25 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £25.06 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth | In Stock | £129.80 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £84.75 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £97.93 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £31.67 |
StarTech.com 12U 22in Depth Hinged Open Frame Wall Mount Server Rack | In Stock | £248.76 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.23 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.45 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £37.64 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.41 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £22.90 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £55.20 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £29.89 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £25.96 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £19.69 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £29.98 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £15.03 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £52.24 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £27.56 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £15.48 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £28.96 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.16 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.90 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.56 |
StarTech.com 19in Cable Management Panel | In Stock | £23.58 |
StarTech.com 12U Wall Mount Server Rack | In Stock | £64.40 |
StarTech.com 15U Wall-Mount Server Rack | In Stock | £111.09 |
StarTech.com 12U Wall-Mount Server Rack | In Stock | £100.03 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.79 |
