Brand
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack
Quicklinx: 6B9SWS00 Mfr#: RK12OD
Product Type: Rack, Rack
11 in stock
£45.81 ex VAT
£54.97 inc VAT
Mount smaller rack mountable devices right at your desk with this lightweight 12U 2 post desktop rack. The RK12OD 12U 19in Desktop Open Frame 2 Post Rack provides the perfect mounting option for smaller Audio/Video and IT equipment where space is limited and a full sized cabinet is not required.
The 12U rack features a compact and lightweight free-standing design that is suitable for installation on or around your desk giving you easy access to the mounted equipment in your workspace. This lightweight 2 post rack is engineered to meet EIA rack mount standards and includes a pack of 20 M5 screws and Cage Nuts, allowing you to mount up to five devices into the rack right away.
StarTech.com 12U Open Frame Network Rack - 19" 2 Post Free Standing Desktop Rack for Computer, AV, Media, IT, Data & Server Room Equipment (RK12OD) - rack - 12U
Rack
Rack Type
Open frame
Rack Size
19"
Height (Rack Units)
12U
Product Material
Steel
50.4 cm x 29.2 cm x 58.4 cm
3-year warranty
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
Rack
Rack Type
Open frame
Product Material
Steel
Rack Size
19"
Height (Rack Units)
12U
50.4 cm
29.2 cm
58.4 cm
UL, RoHS
Limited warranty: - 3 years
6B9S StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £473.44
6B9S StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £18.83
6B9S StarTech.com 25U Adjustable Depth 4 Post Open Frame Server Rack Cabinet In Stock £284.04
6B9S StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £45.81
6B9S StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £37.84
6B9S StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £85.18
6B9S StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.28
6B9S StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £33.88
6B9S StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £33.34
6B9S StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £325.52
6B9S StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £15.71
6B9S StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £31.71
6B9S StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £60.18
6B9S StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £63.56
6B9S StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.54
6B9S StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £634.84
6B9S StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.24
6B9S StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £33.61
6B9S StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £48.75
6B9S StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £63.56
6B9S StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £33.88
6B9S StarTech.com 100 Pkg M5 Cage Nuts In Stock £27.44
6B9S StarTech.com 50 Pkg M6 Cage Nuts In Stock £21.95
6B9S StarTech.com 100 Pkg M5 Cage Nuts In Stock £33.34
6B9S StarTech.com 50 Pkg M5 Cage Nuts In Stock £16.65
6B9S StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £60.18
6B9S StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £31.01
6B9S StarTech.com 50 Pkg M5 Mounting Screws In Stock £17.89
6B9S StarTech.com 50 Pkg M6 Mounting Screws In Stock £18.70
6B9S StarTech.com 100 Pkg M6 Cage Nuts In Stock £29.13
6B9S StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £584.57
6B9S StarTech.com 19in Cable Management Panel In Stock £23.93
6B9S StarTech.com M6 Mounting Screws 50Pack In Stock £18.70
Product Type: Rack
Product Type: Rack
Stock Status: In stock
