StarTech.com 12in TX3 Fan Power Extension Cable
Quicklinx: 6BC6WS00 Mfr#: TX3EXT12
Install your computer fan at the desired location inside the computer case, without stretching or straining the connection. The TX3EXT12 T X3 power extension cable lets you extend the power connection between a computer power supply and a TX3 fan by up to 1ft, allowing you to more conveniently install the fan where needed in the computer case without having to stretch or strain the connection.
StarTech.com 12in TX3 Fan Power Extension Cable - fan power extension cable - 3 PIN internal power to 3 PIN internal power - 30.5 cm
Fan power extension cable
Length
30.5 cm
Connector
3 PIN internal power - male
Connector (Second End)
3 PIN internal power - female
Length
30.5 cm
Connector
RoHS
