StarTech.com 12in SATA to Right Angle SATA Serial ATA Cable
Quicklinx: 8CPLWS00 Mfr#: SATA12RA1
Length: 30cm
Type: SATA
35 In Stock
£5.48 ex VAT
£6.57 inc VAT
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATA12RA1 Right Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a right-angled SATA receptacle, providing a simple 12-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The right-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers a 12in Left Angle SATA cable (SATA12LA1), which provides the same simple installation as this left angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
StarTech.com 12in SATA to Right Angle SATA Serial ATA Cable - SATA cable - 30 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Right-angled connector
Length
30 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
Storage Cable Type
SATA cable
Interface Speed
American Wire Gauge (AWG)
26
Length
30 cm
Red
Connector
RoHS
8CPL StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.50
8CPL StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.16
8CPL StarTech.com 12in SATA to Left Angle SATA Serial ATA Cable In Stock £4.82
8CPL StarTech.com 12in SATA to Right Angle SATA Serial ATA Cable In Stock £5.48
Length: 30cm
Type: SATA
