StarTech.com 12in SATA to Left Angle SATA Serial ATA Cable
Quicklinx: 7P1YWS00 Mfr#: SATA12LA1
Length: 30cm
Type: SATA
18 In Stock
£5.42 ex VAT
£6.50 inc VAT
Make a left-angled connection to your SATA drive, for installation in tight spaces. The SATA12LA1 Left Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a left-angled SATA receptacle, providing a simple 12-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The left-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers a 12in Right Angle SATA cable (SATA12RA1), which provides the same simple installation as this left angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
StarTech.com SATA to Left Angle SATA Serial ATA Cable - SATA cable - Serial ATA 150/300/600 - SATA (R) to SATA (R) - 1 ft - left-angled connector - red - SATA12LA1 - SATA cable - 30 cm
SATA cable
Interface Speed
Shielded
Left-angled connector
Length
30 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: CFAST2SAT25, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Shielded
Shielding Material
American Wire Gauge (AWG)
26
Length
30 cm
Red
Connector
RoHS
7P1Y StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
7P1Y StarTech.com 12in SATA to Left Angle SATA Serial ATA Cable In Stock £5.42
7P1Y StarTech.com 12in SATA to Right Angle SATA Serial ATA Cable In Stock £5.48
Length: 30cm
Type: SATA
