StarTech.com 12in Micro SATA to SATA with SATA Power Adapter Cable
Quicklinx: 6LC8WS00 Mfr#: MCSATAF12S
StarTech.com's MCSATAF12S 12in Micro SATA to SATA adapter cable features a standard female SATA data connector and a SATA male power connector on one end, and a micro SATA female connector on the other, letting you connect a 1.8in SSD (Solid State Drive) to a computer as you would a standard SATA form factor hard drive. The Micro SATA/SATA adapter supports both 3.3V and 5V SSD Drives.
StarTech.com 12in Micro SATA to SATA with SATA Power Adapter Cable (MCSATAF12S) - SATA cable - 30 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Length
30 cm
Connectors
16 pin Micro Serial ATA - receptacle
Connectors (Second End)
7 pin Serial ATA - receptacle , 15 pin Serial ATA power - plug
Red
Storage Cable Type
SATA cable
Interface Speed
Length
30 cm
Red
Connectors
RoHS
