StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter
Customer rating: 5.0* (Write a review)
Quicklinx: 4KX6WS00 Mfr#: PYO2LP4SATA
Length: 0.15m
Type: ATA
13 in stock
£3.60 ex VAT
£4.32 inc VAT
This 12in LP4 to SATA Power Y Cable Adapter features two Serial ATA power (female) connectors and one LP4 male connection - a reliable solution that lets you power two SATA drives using a single LP4 connection to the computer power supply. This durable LP4/SATA Y cable adapter is 1ft in length, giving you enough cable slack to position drives as needed within the computer case while saving the cost and hassle of upgrading a power supply for compatibility with Serial ATA drives.
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter - Molex to to Dual SATA Power Adapter Splitter - power adapter - 4 PIN internal power to SATA power
Power adapter
Connector
4 PIN internal power - male
Connector (Second End)
2 x 15 pin Serial ATA power - female
P/N: 25S22M2NGFFR, 25SAT22MSAT, ATXPOW330HS, ATXPOW350PRO, ATXPOW400DF, ATXPOWER300B, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S25SLOTR, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257
Power adapter
Connector
P/N: 25S22M2NGFFR, 25SAT22MSAT, ATXPOW250PRO, ATXPOW300PRO, ATXPOW330HS, ATXPOW350DF, ATXPOW350PRO, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S25SLOTR, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257
4KX6 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £3.11
4KX6 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £3.60
Customer reviews
Write a review for the StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter here!
Does exactly what it's meant to...
Reviewed by Gary. Review Posted 13/01/2009
What more can I say?
Length of cabling is good if there is a chance of a bit of a stretch to fit to drive...
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Length: 0.15m
Type: ATA
Stock Status: In stock
