StarTech.com 120x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector
Quicklinx: 7TX5WS00 Mfr#: FAN12025PWM
Type: Case Fan
£7.68 ex VAT
£9.21 inc VAT
Add a variable speed, PWM-controlled cooling fan to your computer case. The FAN12025PWM 120mm PWM case fan adds an efficient air cooling solution to computer cases or other enclosures to help ensure optimal performance from internal components.
With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
StarTech.com 120x25mm Computer Case Fan with PWM - Pulse Width Modulation Connector - computer cooling Fan - pwm Fan - 120mm Fan (FAN12025PWM) - case fan
Case fan
Package Content
Y-Split cable
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Ever Lubricate bearing
Rotation Speed
800-2200 rpm
Air Flow
33.2-78.4 cfm
Noise Level
17.2 - 39 dBA
Power Connector
4-pin fan connector, 4 pin Molex connector
12 cm x 12 cm x 2.5 cm
118 g
Case fan
Package Content
Y-Split cable
12 cm
12 cm
2.5 cm
118 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
800-2200 rpm
Air Flow
33.2-78.4 cfm
Noise Level
17.2 - 39 dBA
Power Connector
RoHS
Limited warranty: - 2 years
-10 °C
70 °C
7TX5 StarTech.com Mounting PC Case Fan Screws - 50 Pack In Stock £3.09
7TX5 StarTech.com 12in 4 Pin Fan Power Splitter Cable - F/M In Stock £6.52
7TX5 StarTech.com 80x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector In Stock £7.15
Type: Case Fan
