StarTech.com 10m USB 3.0 Active Extension Cable - M/F
Quicklinx: 81TDWS00 Mfr#: USB3AAEXT10M
Length: 10m
£110.10 ex VAT
£132.12 inc VAT
The USB3AAEXT10M, 10-meter Active USB 3.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 3.0 devices of up to 10-meters (32.8-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations; the active USB 3.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Up to 2 of these cables can be daisy-chained together, allowing the connection to be extended a total of 20-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable.
The USB3AAEXT10M extension cable (USB Extender) supports high speed USB 3.0 transfer rates of up to 5Gbps.
  • Reliable signal regeneration
    The active cable technology allows for signal regeneration, ensuring high-quality data transfer over distances up to 32.8 feet without signal degradation.
  • High-speed data transfer
    This extension cable supports USB 3.1 Gen 1 with speeds up to 5 Gbps, making it suitable for transferring large files quickly and efficiently.
  • Durable construction
    Featuring nickel-plated connectors, this cable is built to withstand wear while maintaining reliable connections for all your devices.
  • Safety compliant
    The cable adheres to FCC and RoHS standards, ensuring that it is safe for use and environmentally friendly.
  • Versatile connectivity
    Designed with a male to female configuration, this USB extension cable can be used with a wide range of USB devices, providing flexibility in device placement.
StarTech.com 32.8 ft Active USB 3.0 Extension Cable with AC Power Adapter - Shielded - Male to Female USB USB 3.1 Gen 1 Type A (5Gbps) Extender (USB3AAEXT10M) - USB extension cable - USB Type A to USB Type A - 10 m
USB extension cable
Active cable (signal regeneration)
Length
10 m
Connector
9 pin USB Type A - male
Connector (Second End)
9 pin USB Type A - female
USB / USB 2.0 / USB 3.0
P/N: PEXUSB3S42V, PEXUSB3S44V, S352BU33HR, SVA5H2NEUA, USB3SAA3MBK
USB extension cable
Plated Connector
Nickel
Length
10 m
Connector
USB / USB 2.0 / USB 3.0, FCC, RoHS
81TD StarTech.com 3m USB 3.0 Active Extension Cable - M/F In Stock £67.37
81TD StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £81.57
81TD StarTech.com 10m USB 3.0 Active Extension Cable - M/F In Stock £110.10
81TD StarTech.com 6in USB 3.0 Extension Cable In Stock £5.41
81TD StarTech.com 3m 10ft USB 3.0 A to A Cable In Stock £7.16
81TD StarTech.com DC Power Adapter - 5V, 2A In Stock £10.11
81TD StarTech.com USB Extender Hub, 10m, USB 3.0 In Stock £118.49
Length: 10m
