StarTech.com 10m Orange Cat6 Patch Cable
Quicklinx: CC3XWS00 Mfr#: N6PATC10MOR
Length: 10m
Colour: Orange
£11.85 ex VAT
£14.22 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. This 10-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. Plus, the cable features a durable orange PVC jacket that enables you to color code your network cable runs as needed.
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
StarTech.com 10m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Orange, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC10MOR) - patch cable - 10 m - orange
Patch cable - CAT 6
Molded, snagless, strain relief, minimised Near-End Crosstalk (NEXT), kink protection, PoE ready
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
10 m
Orange
Connector
RJ-45 - male
RJ-45 - male
CC3X StarTech.com 10m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable - 10 m Patch Cord In Stock £12.09
CC3X StarTech.com 10m Snagless Cat6 Patch Cable - Blue In Stock £12.09
CC3X StarTech.com 10m Gray Cat6 Patch Cable In Stock £13.76
CC3X StarTech.com 10m White Cat6 Patch Cable In Stock £12.35
CC3X StarTech.com 10m Red Cat6 Patch Cable In Stock £12.38
CC3X StarTech.com 10m Orange Cat6 Patch Cable In Stock £11.85
CC3X StarTech.com 10m Green Cat6 Patch Cable In Stock £12.38
CC3X StarTech.com 10m Yellow Cat6 Patch Cable In Stock £11.85
CC3X StarTech.com 10m Purple Cat6 Patch Cable In Stock £12.38
Length: 10m
Colour: Orange
