Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCST10 10m LSZH LC to ST Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-ST patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
- StarTech.com 10m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/ST - OM2 - LC to ST Fiber Patch Cable - patch cable - 10 m - orange
- Patch cable - OM2
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Molded
- Length
- 10 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x ST multi-mode - male
- Connector (Second End)
- 2 x LC multi-mode - male
- Orange
- Limited lifetime warranty
- Designed For
- P/N: MCM1110MMLC
- Network Cable Type
- Patch cable - OM2
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 50 / 125 micron
- Molded
- Length
- 10 m
- Orange
- Connector
- Designed For
- P/N: MCM1110MMLC
