StarTech.com 10m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M
Quicklinx: 7W8LWS00 Mfr#: HDMM10M
Length: 10m
33 In Stock
£34.14 ex VAT
£40.96 inc VAT
Create Ultra HD connections between your High Speed HDMI-equipped devices. The HDMM10M 10-meter High Speed HDMI cable features 2 gold-plated HDMI (male) connectors and durable high quality construction to provide a dependable HDMI to HDMI connection between devices such as Blu-Ray players, HDTVs, DVD Players, stereo receivers and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
  • Robust construction
    This HDMI cable features a PVC jacket that provides flexibility and protection against wear and tear, ensuring longevity in various environments.
  • High-quality connectors
    Gold plated connectors are used to minimize signal loss and ensure reliable connection, contributing to superior audio and video quality.
  • Effective shielding
    The aluminum mylar foil with braid shielding contributes to reduced interference, leading to a clearer signal and a more stable connection.
StarTech.com 10m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - M/M (HDMM10M) - HDMI cable - 10 m
Cable
HDMI cable
American Wire Gauge (AWG)
24
Length
10 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Moulded
Cable Type
HDMI cable
24
Jacket Material
PVC
Shielding Material
Length
10 m
Plated Connector
Gold
Moulded
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
7W8L StarTech.com 1m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £6.66
7W8L StarTech.com 2m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.40
7W8L StarTech.com 3m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £11.72
7W8L StarTech.com 15 m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £49.32
7W8L StarTech.com 10m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £34.14
7W8L StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £13.97
7W8L StarTech.com 7m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £28.06
7W8L StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.69
7W8L StarTech.com 0.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £6.46
7W8L StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.05
7W8L StarTech.com 0.3m (1ft) Short High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £5.98
Length: 10m
