StarTech.com 1m High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M
Quicklinx: 7RWRWS00 Mfr#: HDMM1MHS
29 In Stock
£6.66 ex VAT
£7.99 inc VAT
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMM1MHS 1-meter High Speed HDMI Cable with Ethernet supports the advanced capabilities of the High-Definition Multimedia Interface, including Ethernet data inter-connectivity with compatible HDMI-enabled products, and is fully backward compatible with older HDMI-capable devices.
The cable features gold-plated HDMI (male) connectors which help to ensure a high quality digital connection capable of transmitting high-definition video and multi-channel audio between devices such as Blu-Ray Disc players, HDTVs, DVD Players, DVRs, stereo receivers and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
All StarTech.com High Speed HDMI Cables are expertly designed and constructed of top quality materials to deliver dependable high-definition performance.
  • Versatile connectivity
    This HDMI cable features male 19-pin HDMI Type-A connectors on both ends, allowing for easy connections with a variety of devices.
  • High-quality construction
    Constructed with 28 AWG American Wire Gauge, this cable balances flexibility and durability, making it ideal for different setups.
  • Enhanced technology features
    With support for the HDMI Ethernet Channel and 3D transmission, this cable offers advanced features for an audiovisual experience.
  • Reliable signal transfer
    The gold-plated connectors reduce signal loss, ensuring performance in delivering high definition content.
  • Durable protection
    The PVC jacket protects against wear and tear while maintaining the cable's flexibility for ease of use.
StarTech.com 1m High Speed HDMI Cable w/ Ethernet Ultra HD 4k x 2k - HDMI cable with Ethernet - 1 m
Cable
American Wire Gauge (AWG)
28
Length
1 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI Ethernet Channel (HEC), 3D-Transmission
Cable Type
28
Jacket Material
PVC
Length
1 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
Limited warranty - lifetime
