Make Gigabit Ethernet connections with PoE support. This 10-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. Plus, the cable features a durable green PVC jacket that enables you to color code your network cable runs as needed.
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
 - StarTech.com 10m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Green, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC10MGN) - patch cable - 10 m - green
 - Patch cable - CAT 6
 - Molded, snagless, strain relief, minimised Near-End Crosstalk (NEXT), kink protection, PoE ready
- Length
 - 10 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Green
 - Limited lifetime warranty
- Network Cable Type
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 24
- Plated Connector
 - Gold
- Length
 - 10 m
 - Green
- Connector
 - RJ-45 - male
 - RJ-45 - male
                        StarTech.com 10m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable - 10 m Patch Cord | In Stock | £11.67 |
                        StarTech.com 10m Snagless Cat6 Patch Cable - Blue | In Stock | £11.67 |
                        StarTech.com 10m Gray Cat6 Patch Cable | In Stock | £13.22 |
                        StarTech.com 10m White Cat6 Patch Cable | In Stock | £11.76 |
                        StarTech.com 10m Red Cat6 Patch Cable | In Stock | £11.40 |
                        StarTech.com 10m Orange Cat6 Patch Cable | In Stock | £11.40 |
                        StarTech.com 10m Green Cat6 Patch Cable | In Stock | £11.40 |
                        StarTech.com 10m Yellow Cat6 Patch Cable | In Stock | £11.40 |
                        StarTech.com 10m Purple Cat6 Patch Cable | In Stock | £11.40 |
