StarTech.com 10m White Cat6 Patch Cable
Quicklinx: CC3VWS00 Mfr#: N6PATC10MWH
Length: 10m
Colour: White
More than 50 In Stock
£12.29 ex VAT
£14.74 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. This 10-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. Plus, the cable features a durable white PVC jacket that enables you to color code your network cable runs as needed.
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
  • Reliable connectivity
    The 10m CAT6 Ethernet Cable provides dependable performance for high-speed networking applications. It is suitable for home and commercial use, ensuring a stable and fast Internet connection.
  • Durable construction
    Featuring a PVC jacket and gold-plated connectors, this Ethernet cable is built to last. Its rugged design helps prevent damage from bending and kinking, ensuring long-term use.
  • Enhanced performance
    With minimized Near-End Crosstalk (NEXT) and a 24 AWG design, this cable optimizes data transmission for improved network reliability and speed, essential for streaming and online gaming.
  • User-friendly design
    The molded and snagless connectors reduce the risk of damage during installation and handling, allowing for hassle-free setup in various networking environments.
  • Versatile compatibility
    The cable is equipped with standard RJ-45 connectors on both ends, making it compatible with a wide range of devices including routers, switches, and computers.
StarTech.com 10m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, White, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC10MWH) - patch cable - 10 m - white
Patch cable - CAT 6
Molded, snagless, strain relief, minimised Near-End Crosstalk (NEXT), kink protection, PoE ready
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
10 m
White
Connector
RJ-45 - male
RJ-45 - male
CC3V StarTech.com 10m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable - 10 m Patch Cord In Stock £13.95
CC3V StarTech.com 10m Snagless Cat6 Patch Cable - Blue In Stock £13.95
CC3V StarTech.com 10m Gray Cat6 Patch Cable In Stock £13.71
CC3V StarTech.com 10m White Cat6 Patch Cable In Stock £12.29
CC3V StarTech.com 10m Green Cat6 Patch Cable In Stock £13.95
CC3V StarTech.com 10m Purple Cat6 Patch Cable In Stock £13.95
Length: 10m
Colour: White
