Provides a high-speed, crystal-clear connection to your DVI digital devices, with a long 10-meter cable. The DVIDDMM10M 10m DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and offers 10 meters in cable length, making it perfect for longer connections between your desktop or laptop computer and a DVI-D monitor or projector.
The 10m DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
- StarTech.com 10m DVID Dual Link Cable M/M - DVI cable - 10 m
- DVI cable - dual link
- Length
- 10 m
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- Limited lifetime warranty
- DVI cable
- TMDS Links
- Dual link
- Plated Connector
- Nickel
- Length
- 10 m
- Connector
- 24+1 pin digital DVI - male
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.22 |
StarTech.com 2m DVI-D Dual Link Cable – M/M | In Stock | £10.92 |
StarTech.com 1m DVI-D Dual Link Cable – M/M | In Stock | £8.77 |
