StarTech.com 10m 33ft 40G QSFP+ AOC Cable
Quicklinx: D9TLWS00 Mfr#: QSFP40GAO10M
Length: 10m
Colour: Black
Select:
£267.02 ex VAT
£320.42 inc VAT
Connect your MSA compliant 40GbE QSFP+ network devices with this cost-effective, active optical cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct-attach cables, which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point across-rack network switch or server connections.
StarTech.com MSA Uncoded Compatible 10m/32.8ft 40G QSFP+ to QSFP+ AOC Cable, 40 GbE QSFP+ Active Optical Fiber, 40 Gbps QSFP Plus/Transceiver Module Cable, 40GE QSFP+ Active Optical Cable - Lifetime Warranty (QSFP40GAO10M) - 40GBase direct attach cable - 10 m - black
40GBase direct attach cable - SFF-8436
Fibre optic
Active cable
Length
10 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
Network Cable Type
Fibre optic
Jacket Material
PVC
Active cable
Length
10 m
520 g
Connector
QSFP+ - latched
QSFP+ - latched
FCC, RoHS, MSA
70 °C
Length: 10m
Colour: Black
