Extend the distance between your USB 2.0 devices to 30ft. The USB2HAB30AC 30-foot USB A to B cable features one USB type-A (male) connector and one USB type-B (male) connector, providing a high quality connection to USB 2.0 peripherals.
This 30-foot USB cable incorporates an equalizing chip, which enables it to perform beyond the limits of standard USB cables and communicate with peripherals up to 30ft away. Expertly designed with top quality materials for high durability.
                Reliable signal regenerationThe active cable technology enhances transmission quality, allowing data to travel longer distances without loss of signal integrity.
                Shielded constructionThis cable features a shielded design that protects against electrical interference, ensuring stable and consistent data transfer.
- StarTech.com 9 m / 30 ft Active USB A to B Cable - M/M - Black USB 2.0 A to B Cord - Printer Cable - Extension USB Cable (USB2HAB30AC) - USB cable - USB to USB Type B - 9.15 m
- USB cable
- Technology
- Shielded
- Active cable (signal regeneration)
- Length
- 9.15 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: ICUSB232D
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 9.15 m
- Black
- Connector
- USB / USB 2.0, FCC, RoHS
- 2-year warranty
- Designed For
- P/N: ICUSB232D
|  | StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £58.97 |
|  | StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.67 |
|  | StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £82.96 |
|  | StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £20.24 |
|  | StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M | In Stock | £37.53 |
|  | StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M | In Stock | £32.53 |
|  | StarTech.com 3 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.18 |
