Power your Internal SATA hard drive from an LP4 / Molex connector on your Power Supply. The SATA10POW SATA Data and Power Cable features a combination 22-pin SATA receptacle data and power connector as well as an Molex (LP4) power connector and SATA receptacle data connector, allowing you to create a conventional Serial ATA data connection to a computer while powering the drive through an LP4 connection to the computer power supply.
This high quality SATA power/LP4 adapter cable measures 10in, providing the flexibility required to position the SATA hard drive as needed within the computer case, while eliminating the expense of upgrading the computer power supply for the sake of SATA compatibility.
- StarTech.com 10in SATA Serial ATA Data and Power Combo Cable - SATA cable - 25 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Length
- 25 cm
- Connectors
- 22 pin Serial ATA - receptacle
- Connectors (Second End)
- 7 pin Serial ATA - receptacle , 4 PIN internal power - male
- Red
- Limited lifetime warranty
- Storage Cable Type
- SATA cable
- Interface Speed
- American Wire Gauge (AWG)
- 28
- Length
- 25 cm
- Red
- Connectors
- RoHS
