Make Gigabit Ethernet connections with PoE support, in applications requiring CMR-rated cable. This bulk Cat6 cable delivers reliable Gigabit network connections, which ensures high-performance capability for your demanding Ethernet applications. The Cat6 cable is riser rated for in-wall installations.
This Category 6 cable has been tested for CMR riser installations, and is ideal for in-wall, between floor and elevator shaft cable runs where CMR fire rating is required.
Each of the cables is manufactured using high-quality copper conductors and they are carefully constructed and tested, to keep Near-End Crosstalk (NEXT) well within acceptable limits.
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet and 4K or 1080p video streaming, using cables that include 23 AWG copper.
- StarTech.com 1000 ft Bulk Roll of Black CMR Cat6 Solid UTP Riser Cable - Cat 6 Riser Cable - Cat.6 CMR Ethernet Cable - 23 AWG - Black (WIR6CMRBK) - bulk cable - 304.9 m - black
- Bulk cable - CAT 6
- Technology
- Riser, solid, minimised Near-End Crosstalk (NEXT)
- Length
- 304.9 m
- Black
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 23
- Length
- 304.9 m
- Black
- UL, RoHS, ETL, WEEE, CMP - up to 550 MHz
StarTech.com Cat 6 RJ45 Keystone Jack Network Coupler - F/F | In Stock | £8.11 |
StarTech.com Solid Wire Cat 6 Modular Plug | In Stock | £15.22 |
