Connect your DVI monitor to a DisplayPort equipped computer using a single cable. The DP2DVIMM10 DisplayPort to DVI (M-M) video converter cable lets you connect a DVI capable display to a DisplayPort video card/source using a single cable. The cable provides a connection distance of 10ft and features a male DVI connector and a male DisplayPort connector.
The DisplayPort/DVI video converter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your DVI capable display, while using a cutting edge DisplayPort video source.
DP2DVIMM10 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
- StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M (DP2DVIMM10) - DisplayPort cable - 3 m
- DisplayPort cable
- Length
- 3 m
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-D - male
- FCC, RoHS
- Black
- 3-year warranty
- Designed For
- P/N: DPPNLFM3, DPPNLFM3PW
- DisplayPort cable
- Plated Connector
- Nickel
- Length
- 3 m
- Black
- Connector
- 20 pin DisplayPort - male
- 24+1 pin digital DVI - male
- FCC, RoHS
- 3-year warranty
- Designed For
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £10.03 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £22.37 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £23.48 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.06 |
StarTech.com 6 ft DisplayPort to DVI Cable - M/M | In Stock | £5.82 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £9.68 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £13.46 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £22.99 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £10.29 |
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £25.81 |
StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £13.63 |
StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black | In Stock | £22.22 |
StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £21.59 |
StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £24.14 |
StarTech.com 3ft DP to DVI Converter Cable | In Stock | £17.98 |
StarTech.com mDP to Dual-Link DVI Adapter | In Stock | £93.32 |
