StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M
Quicklinx: 68KRWS00 Mfr#: DP2DVIMM10
Type: DisplayPort
Length: 3m
16 in stock
£33.42 ex VAT
£40.10 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer using a single cable. The DP2DVIMM10 DisplayPort to DVI (M-M) video converter cable lets you connect a DVI capable display to a DisplayPort video card/source using a single cable. The cable provides a connection distance of 10ft and features a male DVI connector and a male DisplayPort connector.
The DisplayPort/DVI video converter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your DVI capable display, while using a cutting edge DisplayPort video source.
DP2DVIMM10 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M (DP2DVIMM10) - DisplayPort cable - 3 m
DisplayPort cable
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
P/N: DPPNLFM3, DPPNLFM3PW
DisplayPort cable
Plated Connector
Nickel
Length
3 m
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
68KR StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.42
68KR StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £27.03
68KR StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.18
68KR StarTech.com DisplayPort to DVI Active Adapter In Stock £22.04
68KR StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £21.64
68KR StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £24.75
68KR StarTech.com 3ft DP to DVI Converter Cable In Stock £15.43
Type: DisplayPort
Length: 3m
Price Range Ex VAT: 0 - 50
