Brand
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M
Quicklinx: 68KRWS00 Mfr#: DP2DVIMM10
Type: DisplayPort
Length: 3m
More than 50 in stock
£32.71 ex VAT
£39.25 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer using a single cable. The DP2DVIMM10 DisplayPort to DVI (M-M) video converter cable lets you connect a DVI capable display to a DisplayPort video card/source using a single cable. The cable provides a connection distance of 10ft and features a male DVI connector and a male DisplayPort connector.
The DisplayPort/DVI video converter cable supports high bandwidth video transmissions, easily delivering monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p - allowing you to take full advantage of your DVI capable display, while using a cutting edge DisplayPort video source.
DP2DVIMM10 is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M (DP2DVIMM10) - DisplayPort cable - 3 m
DisplayPort cable
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
P/N: DPPNLFM3, DPPNLFM3PW
DisplayPort cable
Plated Connector
Nickel
Length
3 m
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
68KR StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £9.43
68KR StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £32.71
68KR StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £26.74
68KR StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.23
68KR StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £15.96
68KR StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.83
68KR StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £23.55
68KR StarTech.com DisplayPort to DVI Active Adapter In Stock £23.95
68KR StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F In Stock £9.82
68KR StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.40
68KR StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £107.20
68KR StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £13.17
68KR StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £21.14
68KR StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £20.91
68KR StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £24.33
68KR StarTech.com 3ft DP to DVI Converter Cable In Stock £16.08
Type: DisplayPort
Length: 3m
Stock Status: In stock
