This Ethernet to MM Fiber Media Converter creates a cost-effective Ethernet to fiber link, transparently converting to/from 10Base-T or 100Base-Tx Ethernet signals and 100Base-Fx optical signals to extend an Ethernet network connection over a multimode fiber backbone.
The converter supports a maximum multimode fiber optic cable distance of 2km (1.2 miles), providing a simple solution for connecting 10Base-T/100Base-Tx Ethernet networks to remote locations using ST-terminated multimode fiber, while delivering solid network performance and scalability.
Easy to setup and install, this compact, value-conscious media converter features auto-switching MDI and MDI-X support on the RJ45 UTP connections as well as manual controls for UTP mode, speed, Full and Half Duplex, as well as LFP (Link Fault pass-through) on/off.
- StarTech.com 10/100 Multi Mode Fiber Copper Fast Ethernet Media Converter ST 2 km - fibre media converter - 10Mb LAN, 100Mb LAN
- Fibre media converter - RJ-45 / ST multi-mode
- Form Factor
- External
- Localisation
- United Kingdom
- Cabling Type
- 10Base-T, 100Base-FX, 100Base-TX
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- Max Transfer Distance
- 2 km
- 7.3 cm x 9.7 cm x 2.3 cm
- 90 g
- 1-year warranty
- Form Factor
- External
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Cabling Type
- 100 Mbps
- 1310 nm
- 2 km
- Status Indicators
- Port duplex mode, power, link/activity
- Flow control, auto-negotiation, half duplex mode, full duplex mode
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q
- 1 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - ST multi-mode female x 2
- FCC, RoHS
- Power Device
- External power adapter
- 7.3 cm
- 9.7 cm
- 2.3 cm
- 90 g
- Limited warranty - 1 year
- 0 °C
- 50 °C
- 0 - 90%
StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Converter SC 2 km | In Stock | £60.71 |
StarTech.com 10/100 Multi Mode Fiber Copper Fast Ethernet Media Converter ST 2 km | In Stock | £65.54 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
